1 - 8 of 8 Posts
Kit # is 60134-01.
This kit has the crossbar that provides mounting for the existing turn signals on 00-01 FXDX models. The crossbar has male, fine threads. The oem part # i have come up with for the turn signal is 68425-01. Will these in fact work??
The kit is being pulled off my 02 lowrider for use on my 06 dyna. The 06 dyna has a different thread pitch on the female threads of the turn signal so they wont work.
The more i research this the more confused i get. In the end, i might just helicoil my 06 turn signals to match the thread pitch
Please help me out if you know what i can do to make this set up work. I have searched here but get conflicting info
Thanks in advance
the dealer should be able to hook you up with the right P/N - but just in case, I'm using the same laydown plate you listed. Recently ordered a replacement rear turn signal and the P/N is 68425-01. This is the P/N that fits an 01 FXDX-T rear turn signal and I'm sure fits most other dyna's, not sure if it is the same as the 06. Hope this helps.
Thanks a bunch eod..please respond back when you get it to let me know if the threads are the same. Your crossbar is fine threaded-Correct??
Sorry - should have been clearer, I have it installed already. Those two P/N's you listed are compatible (same size/thread). At home right now, tomorrow (I'm 14 hrs ahead of you) at work I'll get the size/pitch of the threads on the bar and post back if someone else hasn't already.
The thread pitch was different on my 2005 FXDI and the thread that came on the chrome bar that mounts through the layback licence plate.
I used the following on my 2005 FXDI:
HD Relocation Kit
Chris Products Turn Signals
Black Nickel Turn Signal w/ Amber Lens
Dennis Kirk Part Number: 211729
Manufacturer Part Number: 8501ABN
Price: $20.99 each
blueballs said:
Kit # is 60134-01.
Thanks in advance
Ran in to the same thing and got the dealer to do a swap out for my rears with fronts. The fronts have a matching thread pattern.
HTH,
Chuck
Blue - 5/16" x 24 is the bar size - sounds like at some point they changed the light housing thread on the dyna.
1 - 8 of 8 Posts
