hi....maybe someone here can give me their two cents worth....first of all this is on a stock 99 FLHTCUI with stage 1 upgrade...maybe also a 95 incher done when the cam bearing recall was done....didnt own it then and not sure if it was changed.....anyway I went for a stroll this weekend and got out of the city a way and took off from a stop and just wound it out a little....shifted at 5500 rpm and as I was getting ready to go to 3rd gear there was a loud clacking noise on the cam cover side of the engine....pulled in the clutch let it idle down....the clacking stopped but the engine wouldnt idle....had to hold the gas on a little to keep it running...started to ease it back home and it seemed to be running ok so thought I would rap it open again...did the same thing....babied it the rest of the way home and it died in the driveway....wouldnt start again....pulled the cam cover...everything looked good there and then pulled the rocker covers....dialed the intake and exhaust movement and they were the same on each side....no codes on the pc engine lite.....any clues???....TIA!!
norm
norm
