:huh: Shouldn't the primary cover come off easily?(89 4 speed sportster), cause mine won't. Don't like to lever to much in case of damaging mating faces. Bumped gear shifter while taking out of garage, and now unable to change gear(stuck in first) trying to have a look but primary cover in my way. Any ideas would be appreciated. Thanks Matt.
did you remove the clutch adjust lock and undo the aduster screw??
No, I took off clutch adjust access cover,spring+ lockplate, slackened primary chain tension screw and removed all bolts(basically followed clymer manual) Do I need to undo adjuster screw??
screw the aduster in and the nut will come out and off it comes
