· Registered
Hey whats up I am dealing with a charging problem on the stator if you take a meter one lead from the stator plug on the block the other lead to ground or block+you ring out continuity or .o2 ohms is this a for sure faulty stator when i check the out put at 1000 rpm +2000 it checks ok
Oh, and I forgot to add that this is on my 98' Heritage Springer.
Thanks, in advance, for your help.
· Registered
Oh boy. It stinks something aweful. Well, this just confirms that my stator is bad. What harm can this do to my bike if I decide to charge the battery and ride it until I can fix it? Also, I bought a new regulator thinking this was the problem, do you think the stator burned it up too?
Thanks again.
· Just bad
I wouldn't ride it unless you leave the stator unplugged - even though there ought to be a fuse or fuse link blown anyway. If you're lucky, that fuse may have saved your regulator but don't hold your breath. You'll know when you get the new stator in :)
