Please help with some simple step by step wiring instructions to install a mini tach (P/N 67943-96B) on a 02 RKC. I'm looking at the instructions that came with the mini tach. I've removed the hardware on the bike - I just need help with wiring. The instructions say remove seat, battery, right saddlebag, and right side cover, aren't all the wires connected in the nacelle?
On the 2002 I don't believe I need to plug any wires under the side cover / battery area. I removed the headlight and found in the nacelle a orange/white wire and a black wire, both with connectors on them and a pink wire with a weird clear plastic plug cover on it.
The wiring harness for the tach has a red wire, black wire, and a yellow wire.
I guess I just need confirmation that this is how the wires mate up in the nacelle and no wires are plugged into any other area.
Red (lead) harness wire to orange/white nacelle wire. Is red Power?
Black (ground) harness wire to black nacelle wire.
Yellow (Signal) harness wire to pink wire. Is pink wire the one that registers rpm?
