1 - 2 of 2 Posts
I have a 2000 deuce and want to change to dual disc brakes in front.I have the right slider with braKE MOUNT and the wheel and the rotor what i need is the caliper,does anyone know where i can buy one and the part # or a set that will interchange.
MY DEUCE IS A 1550CC
570G S&S CAMS
Tpp lock up
10.5 pistons
heads ported and polished
very fast but i need it to stop
so please help if you can.
i don't know how to insert a picture but its a real nice looking bike.I rode it to viet nam in april from Thailand and had a blast even though i hit a water buffalo lol but not at speed thank god:xhere:
Is the lower from a 1999 and earlier frontend or 2000 up frontend? I have not been able to find a dual disk front for the 2000 up forks unless you go with the FLH forks. Then you need to change both lowers and use the brake to fit. If you have found a 2000 up right side lower you can use the right side brake off the touring models, left side are the same. (pre08)
1 - 2 of 2 Posts
