My 04 Fatboy is giving me the blues it’s running like crap like its missing or out of time!! I had a problem with the fuel pump Hoses so I replaced everything inside the tank!! Replaced injectors!! New crank position sensor!! New battery!! New coil! And new ecm!! I’m at the end of my rope I don’t want to keep buying new parts unless I know it’s for sure the part I need can anyone help??
did it have any codes set? before you tossed over a grand in parts at it?
what is it with all you shade tree mechanics hanging new parts, until you run out of parts to change,,, and then ask for help...
what i always like to say was,,, hope you didnt toss out all those old parts,,, because they are still good.
No codes!! The problems didn’t happen till I put the new pump hoses regulator in the tank!! Before I did all that I had an exhaust leak so I changed the rings!!
