Will the HeavyCycles' LED tail light fit with the Street Glide? Does the Street Glide have the Laydown type tail light?
Motown_LEO said:Will the HeavyCycles' LED tail light fit with the Street Glide? Does the Street Glide have the Laydown type tail light?
Motown_LEO said:Doc,
Can you post a picture of what the Brake Light "Blue Dot" option looks like?
Does this strobe while running and turn solid when the brake is applied? Or is it just lit blue when the brake is applied? If so, can you make one that has a strobe in it?
That is correct!Trapper1 said:Dr., That stage 2 FX kit will fit my 06 super glide custom ,correct?
Hey Motown,Motown_LEO said:Doc,
I sent you an email inquiring more on the LED for the street glide...
How difficult are these to install?
Thanks.
I also emailed this to you...jimclaypool said:How do you release the wire terminal from the plastic connector for the front fender tip wire harness. I was installing the Heavycycles LED replacement front fender tip and inserted the terminals backwards into the plastic connector. I tested and thought I got it right but not!! Now I need to get them released and swapped. Got to be a trick with a pin inserted that releases them, but not evident to me. Thanks in advance for help.
Jim
