I was woundering if the new Victorys were having the same issues with heat due to EPA regs. Are they equiped with CATS? Being air cooled I would think they are heat up as well.
please explainNo heat issues.
Bikes run lean from factory, but disconnecting the O² sensors is a 30 second procedure allowing them to run a bit richer and even cooler.
I am 100% HD.Harleys aren't oil cooled unless an oil cooler is installed.
To clarify your statement regarding the above:I am 100% HD.
But only 1 HD has Oil cooled heads and that is a 1200. All the oil coolers in the world will not coll HD heads any more than they are with out one.
The small amount of oil that flow to the heads is for lube and carriers so little heat awy it is not worth even looking at.
Second take a trip to A victory shop you will hear some terms you are use to hearing.
Stage1, tuner, DYNO ect they have there EPA issue also.
Actually, oil coolers are standard on all the HD's with 103's, which is most of the big twin line, other than the Supergide and Street bob. OF course, the V-rods are water cooled.Plus the Victory's run their oil pressure at 80 psi at idle not 2 psiI like HD. Which allows better removal of the heat that builds up in the motor, gets it cooler quicker...
Yep an oil cooler is optional on a HD and stock on a Vic....Helps a lot!! :woohoo:
Oil removes the same amount of heat at 2 psi as at 80psi. It's non compressable so the as long as the volume remains the same, heat removal remains the same. Now, upping the volume of oil pumped through the system can increase heat removal.Plus the Victory's run their oil pressure at 80 psi at idle not 2 psiI like HD. Which allows better removal of the heat that builds up in the motor, gets it cooler quicker...
Oddly enough; the new Freedom motors run a bit hotter than previous models. The Vic's were designed to be oil over air cooled so oil flow to and from the heads reflect that design. On earlier models the oil cooler was too big and actually over cooled the motor. Now they look like a standard HD oil cooler.To clarify your statement regarding the above:
Stage 1 is for a different exhaust note, nothing else. Tuner is to add fuel once a set of cams are put in, no one adds a fueler to a stock Vic cause you just don't need it...You dyno a Vic to see what the $1500 dollar cams did to bump up performance, usually it is in the range of 27% but some see up to 30% improvement in HP and torque...
So let's be clear, yes every manufacturer is feeling issues from the EPA tards, but Victory dealt with them BEFORE the desisgned the motor not afterwards...
All you are referring to are mods not anything to do with EPS BS![]()
The V-92 "Hammer" engine also held 6 quarts of oil. Between that and the huge oil cooler, if you put a good synthetic oil in it and the temps were below 60 degrees the engine would never reach full operating temperature while the bike was in motion...On earlier models the oil cooler was too big and actually over cooled the motor.
+1 I like to see that wonder pump, 80psi at idleActually, oil coolers are standard on all the HD's with 103's, which is most of the big twin line, other than the Supergide and Street bob. OF course, the V-rods are water cooled.
That just leaves the Sportster line, other than the two Dynas mentioned above, without oil coolers.
The oil pressure deal is dead on however. Really, 80 PSI at idle? Interesting!
Front to the right, rear to the left.I never looked at the crank that close and didn't realize the rods are offset like that. Also good to know the wheels can't scissor too. Which cylinder is to the left?
.I definately found this to be true. I test rode some 2011 Visions and the 2012 Cross country tour and was surprised at the amount of heat the engine was throwing back. The dealer was touting how much cooler and more efficient the Vic was at diisipating the heat over a HD but not that I could tell. I would say they ran as hot as the HD.
