Closet Doof
Picked up my 08 Screamin Eagle Ultra on Saturday. Wow! Love the bike, but headset is a problem.
If I turn the volume up enough to listen to the radio, I get loud popping sounds in the headset, like like an electrical short right in my ear. I don't think its a loose wire, because it only does it with volume, especially bass.
Do I need to go back to the dealer for a new one, or is this typical of stock HD headsets?
I have the same problem. I think the HD headsets just can't handle significant base without popping/buzzing. I turned the base down and the issue went away, but the sound quality is not what I would like. seems to me the only way out is a different headset.
By the way - I have two headsets - one for the wifey - and they give identical problems.
Closet Doof
Thanks for the info.
I would have bought the second headset when I picked up the bike, but they were out. Guess I saved myself $200 not buying more junk.
Ordered a J&M so we'll see if that's better.
they work great if you can get them close to your ears, i use a piece of foam that puts it right on my ear when my helmet is on. hope this helps some plus you can normally pick up a set on ebay for around 100 bucks or so
