1 - 8 of 8 Posts
I'm planning a simple 95" build on a EFI 04 Road King. I'm boring my jugs, using SE flat top pistons, adding a TW26A cam, adjustable push rods, DFO tuner, high flow air cleaner, vance & hines headers with SE Pro slipons. I've got some money in the buget for some head work. WHat is it that I can do with the heads for low end torque?
Thanks for your help, I'm new here and appriecate all the advice I can get.
Welcome to the club. Check with our sponsor bigboyzcycles on the head work. The can set up the compression as desired for your cam. Believe it's about $340 for the heads including decking.
High end for a street bike is for example Dewey's stuff at www.deweyspegs.com. He likes the TW37G in combination with his heads.
PS: you may not need adjustable pushrods when you take the heads off anyway.
Infidel
Head work helps on the top end.
If you had bigboyz do their thing (I think its around $300 but ask springer- to be sure) you could go with a TW37. This is a very reliable combo that ought to yield 100 HP and 100 ft lbs of TQ.
You'll be all :D :D :D :D
You mean that there isn't any low rpm torque to be added by doing work on the heads? I don't want 100 hp & 100 ft lbs TQ at 4-5000 RPM's I want it early.
Head work will help out over the entire RPM range. The cam you select will help determine at what range your bike performs at. Add a good exhaust and you are on your way to plenty of low end torque.
Premium octane member
You may also want to think about gear drive cams, They are well worth the extra money....Its give you piece of mind...Don't know if it will blow the budget though.......Like V-hog said may be able to scrap the adjustables and save some money there....you must ask your head porter though......I see you are in P.A. you may want to switch the DFO for a powercommander as there is a reputable dyno tuner out there.(cant remember name though.sorry)
The builders listed below have all been used by either someone here, or someone on another board. Each builder has a different philosophy and method to their builds. Some will build it for maximum horsepower, others for torque. Most offer both a radical and mild build. Radical builds chase dyno numbers that can eat up a track at Wide Open Throttle. Mild builds tend to be more dependable and can eat up the freeway miles at cruising and riding speeds. Everyone will suggest a "package", or a combination of heads and cams that the builder has had success with. And here is the interesting thing, all the packages are a bit different. Each builder has a different way of working the heads, and thus a different cam is suggested. Each one may suggest a different exhaust too. Try not to mix up builders packages by trying to select heads from one builder, and cams and gears from another, and try to build it together. That may lead to problems.
For me, the thing I had to remember was not to get caught up in the HP/TQ numbers game (very difficult for me to do). All I really needed to do was let the engine breathe better, and run cooler, so it could work easier. My build with AMS heads in no way produces high dyno numbers when compared to others. But it does exactly what I want it to do.
And now, the list of builders I found posted on another forum:
AMS
212 Carroll St
Ft. Worth, TX 76107
1-800-210-8675
http://www.automotivemachine.com/
Dewey's Custom
3108 Pontiac Drive
Farmington, New Mexico 87401
505-326-5998
http://www.deweyspegs.com/products.html
Baisley Hi-Performance
5511 N. Interstate Ave.
Portland Oregon 97217
(503)289-1251
Hal's Speed Shop
1915 S. Moorland Road
New Berlin, Wisconsin 53151
262-814-7282
http://www.halspa.com/default.asp?P=2
Nallin Racing Head Service LLC
3770 Puritan Way Unit E
Frederick, CO 80516
(303) 833-4500
http://www.nrhsperformance.com/headworktc.shtml
Head Quarters
Parts Order Line 519-892-6992
Tech Line 519-892-6999
http://www.head-quarters.com/
Bishop Performance
26448 Grand River Ave.
Redford, MI 48240
313-537-5026
http://www.bishopsperformance.com/heads.htm
Full Sac
Lake Havasu City, Arizona
928.505.2912
http://www.fullsac.com/products_cylinder_port.htm
Engines by Otto
Sugar Grove, IL
(630)466-3900
Big Boyz Cycles
685 Riverside Dr.
Augusta, ME 04330
207-621-1001
http://www.bigboyzcycles.com/
Richard's Engine Developement
16-3 Bonny Eagle Road
Standish, Maine 04084
207- 221-0765
http://www.sacoriver.net/~red/index.html
R&R Cycle
Manchester, NH
603-645-1428
http://www.rrcycles.biz/
Hillside Motorcycle & Machine
5225 S. Main St.
Munnsville, NY 13409
Phone (315) 495-6650
https://www.websitedesignpros.us/hillside/hillside/frame.asp
Short Block Charlie
2015 E 5th Street #18
Tempe, AZ 85281
800-597-0922
http://www.motorcyclemachine.com/services-hdperf-packages.html
Hardy Heads
1534 N. State College Blvd.
Anaheim, CA 92806
714-490-0155
http://performancetechniques.com/hardeyhead9/index.htm
Hemi Design
3147 South Austin Blvd.
Cicero, IL 60804
(708) 652-5450
http://www.hemidesign.com/
Revolution performance
1312 Pilgrim Road
Plymouth, WI 53073
Toll-free: 888-779-6885
920-892-2109
http://www.revperf.com/twin.aspx?action=cylHeads
Dave Mackie Engineering
2065-H Sperry Avenue
Ventura, California 93003
Tel: 805-658-6969
http://www.davemackie.com/
FLO Headworks
1150 Pike Lane, #2,
Oceano, CA, 93445
805-481-6300
http://www.floheadworks.com/Default.htm
JET
10 Springbrook Rd
Westerly, RI 02891
401-595-9507
http://www.johnsonenginetechnology.com/JETPAGES/packages/95_twin_cam_fuel-injected.html
BC Gerolamy
3322 Luyung Drive
Rancho Cordova, CA 95742
916-638-9008
http://www.bcheads.com/twin.htm
John Sachs, Sachs Race Bikes
Ft Lauderdale, FL
954-473-2980
Bob Wright, R&D Performance
952-955-1198
Leo Hess, Full Blast Engineering
605-332-2659
Cycle Rama
7200 73rd Street N.
Pinellas Park, Fl. 33781
727-546-0889 / 727-546-0945
http://www.cycle-rama.com/HPProducts.html
Port Pros
12108-C Roxie Drive
Austin, TX 78729
512.257.0222
http://www.portpros.com/HarleyDavidson.html
Big Al’s Performance Parts
110 John King Rd
Crestview FL 32539
704-425-0411
http://bigalsperformanceparts.com/
1 - 8 of 8 Posts
