Well Jimmie from Harley House Call's came over today and installed my AMS heads and Andrews 26-G gear drive cams.
He started at 9:00am and finished at 4:00pm. I took some pics along the way, but had to leave the install for a commitment at my kids school. He said everything went well, no problems or unexpected findings.
It was interesting to compare the AMS heads to the OEM ones. Jimmy looked the AMS heads over and said they looked great. I pointed out the heat coated exhaust port, something he had never seen before. I said that treatment is an AMS specialty. Jimmie pointed out the exhaust valve on the stock head, it was ashen white from the high temps. No excess carbon build up. The piston tops looked good too. There was some coating, but nothing concerning.
When I stopped by again, he had the heads on, and the cam cover off. The guts were pulled out, and he was installing the cams and gears. Everything was going well he said.
When I got home at 3:30, he had the exhaust back on, and the cams installed. I put on the gas tank, and filled it, and hooked up the battery. He kept the sparkplugs out, and cranked the engine awhile letting the top end and cams lube up. Then he put the plugs in.
As I ALWAYS do, when I have major work done on either of my vehicles, I made a sign of the cross by waving a wrench over the bike. Jimmie hit the starter and the bike fired right up. It was clacky at first, then settled down. Although the idle was high, I could hear the faint whirring of the cam gears. We let the bike run till it was warmed up and shut it down. Since it had just finished raining, Jimmie did not take it for a test ride. He told me that with the heads and new cams, I would have to get it retuned on a dyno anyway. The bike sounded good.
About half an hour after he left, the weather cleared up. I took the bike for a quick spin around the block. It ran like another bike. I COULD FEEL the difference. I look forward to another dyno tune.
And now the big question.....
How much do you think this cost?
A factory trained mechanic came to my house and swapped heads and installed gear drive cams. He was there from 9am to 4pm.
