Is anyone out there using the headquaters 0039g 580 lift cam with headquarters heads and if so are they a good torque cam and how would they compare performance wise to the tw-6hg cam 590 lift with the same heads and Is a stock throttle body efficient enough to get the use out of these high lift cams and if not your suggestions are welcomed. Thank you much.
Ummm....wasn't this just covered?
Go with the HQ package, the components are designed to work together.
I've got the HQ System 95 in my '96 RoadKing and the 1550 Hi Comp system in my Dresser. Both work flawlessly and provide lots of torque where it is most needed.
Terry C.
