Would you have any ##'s on that build froma dyno?? SAE.mvent said:Brassman,I'm running the 34 cam ,95"flat tops,SBC heads,an e-pipe with a map off Sert and bike runs great,reliable like stock only faster,Mike
That motor has to be very torquey. You have to be over 205 on the ccp. i bet it does haul the mail. What is the build of the other motor?mvent said:Don't have any dyno numbers,but I can tell you it runs dead even with another bike with HQ setup which dynoed at mid 90's hp and just about 100 ft.lbs. of torque
I'm running a Cometic .030 head gasket,my chambers cc at 82,haven't done a cranking compression test,never felt the need,never any starter kickback or detonation,very nice build for low bucks,Mike
That should be about 9.6:1 CR and about 185 ccp.mvent said:I'm running a Cometic .030 head gasket,my chambers cc at 82,haven't done a cranking compression test,never felt the need,never any starter kickback or detonation,very nice build for low bucks,Mike
