1 - 2 of 2 Posts
When changing heads is it necessary to replace the cylinder base gaskets?
Seems to me that as long as you leave the cylinders in place you can leave them alone.
Also
When measuring cam gears on a EVO do you have to use the pins described in the manual? Why can't you use a couple of drill bits and just compare the old gear to the new one? Can any HD dealer remove/ press on a cam gear and how do I know he got it right?
not worth the potential leak...its only a extra 30 min or less of work when the heads are off...how long to pull it all apart again after its together?
1 - 2 of 2 Posts
