I just changed my head gaskets about 100 miles ago and I blew the gasket agin on the front cylinder. I thought I was having tuning problems with my carb but I now think it is due to another blown head gasket. You can see a mist in the front spark plug side of the head when I go to start the bike, I an using compression releases but I forgot to use them once and the bike didn't like that to much. I just bought these heads about 500 miles ago and installed them and I blew the head gasket and changed it every thing was all good then this morning a big cloud of smoke and a hiss and I knew it did it again. Any ideas. I am running a 95 ci set up 10:5:1 Wiesco Pistons with 258 SE cams SE Heads and I am using SE high compresion head gaskets. I asked for some help before and it was mentioned to get the cometicc head gaskets, which ones should I try. I also an having a problems with a off idle ping could any of this be related and can some one point me in a good direction to get started on this bike back on the road?
