?? concers the running light/turn signal module that HD offers. Would someone who **has** the module installed answer this for me please.
The Badlander module I have seen that serves this same function operates like this: rear signal light is on (running light), when you turn on the directional signal - it starts to blink. When the directional signal is turned off, the light goes off for a few seconds and then turns on as a running light. Having followed bikes with the badlander module I do not like it - every damn time it resets and turns on I instinctively grab for a brake cause I see a new flash of red light. Just don't like that at all - for the record maybe the newer badlander modules does not do this - no idea.
What I'd like to know from someone who actually **has** the HD module installed, is if it workes the same way. In other words, when the turn signal turns off, does the light turn off for a few seconds and then turn on as a running light?
Normally I just change the guts of the signal housing and rewire - my g/f thinks this may be easier.
TIA
TIA
