I got an HD mini tach off ebay.
Can anyone tell me where the wires hook up?
Black - Ground?
Red - Switched Power?
Yellow? - Coil???? (if so, connected where)
Thanks!
0043--Licensed to Doof!
Call your dealer. Tell him you lost your instruction sheet for the tach. He can print out one for you. The guys at the parts counter should be able to help you. Mine does it for people all the time.
Black - Ground?
Thanks!
If it is for A TWIN CAM then it hooks up to the pink wire located in the console.
Discussion Starter · #4 · (Edited)
Found the PINK wire under the nacelle with a white connector on the end. Used the Fluke to double check the wire has continuity with the pink wire on the cruise module. Guess its there for the police models since they have tachs. Thanks for the help.
