HIPPO _ Please read _ Alarm Problem
Hippo, and to anyone else that may have information. 2002 ultra, with factory security system... Security worked great when i got it, (2 damn weeks ago) but now the remotes dont activate it or disable it. Unless... i remove the seat and put the fob down by the battery / security module.. now i did go through and program the manual overide, so im ok to ride the thing, but in a nutshell, I have no distance whatsoever with the fob's.... I have replaced the 2032 batteries in them, made sure the bikes battery is fully charged... so what gives... do you have any idea why i have no distance with the fob's??.... I have a friend that has a 2001 road king, and has the same problem with his security... yes it is under warrentee, but if its something i did, I would like to know.... I have done one simple mod, and that was to run a wire from the battery to the tourpack for lighting... which i have removed (thinking that the wire is causing interference with the security module or something).. but the same... Please help if you can!
Doug
