1 - 8 of 8 Posts
I changed by backrest and want to attach the emblem to the new rest. What kind of glue does HD use? Looks like some kind of putty. I had to use my wifes hairdryer and a wooden pry stick to get the thing off.
The emblem I put on my FXDWG3 used some sort of 3M adhesive tape. I have to take it off, too ------- I'm thinking maybe acetone (scary, I know) will dissolve the adhesive???
3M emblem tape is what you want to stick it on with. Stop by a bodyshop and ask 'em to sell you a piece. You can cut it to fit with sharp scissors.
3m tape
it's called 3M automotive acrylic plus attachment tape. It comes on a roll. Kinda pricey for one job. If you have a friend in the body shop biz, hit him up for a few pieces. It's really sturdy stuff. Goof off will soften it too. I usually rub it off with my thumb and finish up with a solvent or thinner, then buff.
Knower of Stuff
Note the 3M adhesive tape does have a cure time. Let it set for at least 12 hours before subjecting it to vibration. Cures in 24.
Just and FYI.
Ride safe.
You can use 3M Emblem adhesive, a tube costs about 4 bucks at your local auto supply. It is a clear adhesive, good for gluing on emblems and trim. It is also good for gluing the rubber bead on the chrome dash panels on your superglides and lowriders.
I use heavy duty velcro on mine, but it depends on what kind of emblem you have. I used to have a solid metal one that velcro did not work for because it was too heavy, I switched to a very light emblem and the velcro is perfect.
90 FXRS LOWRIDER
acetone, (fingernail polish remover), zippo fluid will also take any sticky residue off with ease. soak it, let it sit for a minute, soak again and rub. soak and rub as needed. depending on how much stuff you have left on the sissy bar mount or whatever. if you do this on a painted surface, make sure to wash the spot and wax afterward.
1 - 8 of 8 Posts
