I am repairing and painting a used tourpak and I want to remove the hinges to do a cleaner job. I've used alot of different pop rivets and mono bolts but never the kind of rivets they have on the hinges. I want to stay with the stock rivets. Has anyone ever used these and what special tool is required if any.
Thanks for the help....
Bud
drinker of fine ales
Your local dealer should have them, pretty cheap as I recall. The special rivet tool itself is damn pricey though, over $200.00.I couldn't justify the expense to have it lay in my toolbox.If your only gonna do it this one time just let the stealer install the rivets.
You'll also go through a few drill bits getting the damn things off, tough as hell.
Seasoned Prime Member
The rivets are stainless steel so they don't rust. Best drill bit to use is Cobalt, then Titanium coated. Cobalt bit, a few drops of Rapid Tap cutting oil and drill REAL SLOW. If you heat up the end of the bit it's shot!!!:xhere:
I was looking at some of the different tools for doing these kind of rivets. Has anyone tried making one up out of a heavy duty "C" clamp and putting/making a fitting on the screw end to expand the rivet ? I don't have alot of trust in my local dealer especially after doing all the fiberglass/ paint work on this thing.
I'd rather screw it up myself than pay someone to do it.......
thx. Bud
