I started a new thread as the situation has changed form my original post. 03 FLHRCI, Stage I ECM Flash, Fullsac True Duals, and B&E Superflow Mufflers. The original PCIII would not load maps. DynoJet graciously replaced the unit. The new unit loaded the map fine. Installed it on the bike and bike would not start. Battery was slow to turn over. Disconnected PCIII and hooked back up stock. Bike started and charged the battery. Hooked up the PCIII again and the bike started. Reconnected the PCIII and buttoned everything up. Bike will not start now and there are no lights on the PCIII when the ignition is initially turned on. Any help is appreciated as this is turning into a real pain.
