I have a Harley Davidson Performance Combination Speedometer/Tachometer KMH # 70900071A Gauge, and have had it on my bike for around 8 years and everything has worked great but, recently the fuel level indicator bars have been stuck on Half way even with a full tank.
The low fuel indicator light icon does still work.
I also have a flush tank mount kuryakyn Fuel/Battery gauge and the fuel level indicator light bars work fine and show a full tank, when full, and lowers as i use fuel accordingly so all good there so, I know it's not the fuel level sender unit float getting or being stuck.
Does anyone have any ideas as to why my Harley Davidson Speedometer/Tachometer gauge # 70900071A fuel level indicator bars would be stuck on Half way
First step would be to pull the sending unit and check the resistance range with a VOM.
You're electrical diagnostics manual should have the correct range for your bike.
