1 - 2 of 2 Posts
I purchased a 94 fatboy a month or so ago and it ran great until recently. Now it's hard as he'll starting up and acts starved for fuel at cruise. Acceleration is fine, once warmed up, but idle is a bit rough. The only visible modes are an early SE ignition and V&H long shots exhaust. The ignition pick up is advanced as far as possible by a local mechanic, new plugs (SE thin electrode), WD40 test shows no obvious air leaks, and plugs show it's running a bit lean (slight amount of grey/white ash). Things I've done include installing vent line between tanks (totally missing), adjust air fuel mixture per CV Performance guide (not sure how well I did as it's running a bit lean), and Pulled baffles as they were cut back already. HELP, and thanks
1 - 2 of 2 Posts
