1 - 11 of 11 Posts
95 ci
10.25 to 1 SE PISTONS
heads ported and polished
roller rockers
S&S 570G cams and lifters
V&H big shot staggered
SE air cleaner and 6200 rpm Ignition
gonna try dynoing it soon....
was stock carb before..went with his Rebel..quick service...ordered on a friday..go it wednesday
ok.fresh off the dyno
and short of it being a tad fat..down low..and a twist of a screw..carb was perfect
hp103
tq107
0043--Licensed to Doof!
I've been thinking about sending him my CV44 for him to work his majic. Whats the specs of your Rebel?
hp103
tq107
What were the numbers with the stock carb? Do you have a dyno to compare the two carbs side-by-side?
Discussion Starter #8
well..had it dynoed..before the big bore and carb
so..hard to compare
gonna get the sheet..will try to post the specs on the rebel
bump?.....
Bob Wood is the KING of Carbs, Last year when i was building my 98" motor i went and met him in person to hand him a new 44 S/E carb to do his magic.I told all the specs of my build and he said that he would have it back to me in a few days . It came 3 days later and if you no ant thing about carbs you can look at his work and see all that is put into his carbs. Not only did i meet him in person at his shop. He gave me and BigMan a tour of his one man shop. You would think from the size of his shop he would have about 40 people working for him. Wrong , he runs the shop all by him self except for his wife and mother-in-law that takes orders and does the shipping. Even got several free t-shirts. I told him where i was going to have the motor Dynoed and he was there the day it was done and the only thing he changed was the main jet. The dyno showed perfect on the air/fuel mixture and has had nothing done to the carb . That was a year ago and 12,000 miles ago. The man even carried me to eat lunch after the dyno. He is a man of his word and will talk shop with you as long as you need to ask questions. I would highly recommend him over any other carb builder and his cams also. The proff is in the end results and i have found no one else with the same build as mine that makes the numbers i do. Just call him and go for it . You want regret . Booggerbe
Discussion Starter #11
here are my specs
even though I am a low life non suscriber..lol
pilot..52
tbp 400
main.094..2.39mm
inside majic..couldnt tell you
but the sumbitch works
1 - 11 of 11 Posts
