I don't have any numbers for you but our local HD shop has two cam plates on display in the service area. One has gear drive cams and the other has the chain drive with just the rear chain and tensioner. The gear drive spins very easily. The chain drive is a bear to get to turn (and thats without the outer chain and tensioner). You actually have to grab one of the cam lobes to get enough grip to turn the thing. Like I said I don't have any #s but this has to give you a few ponies!Dirty Jim said:Wheres the proof that you can gain 4 horsepower by changing to gear driven cams?
what do you know?...you think S.E. parts are fastcsoday said:Jim, I have been asking for that proof for over two years but it has never surfaced. The internet theory is that "reduced mass equals 4 HP" :laugh: .
Others claim "more precise timing equals 4 HP" :laugh:
Maybe the combination of the two equals 4 HP :laugh:
I say, Show me the dynos
By the way, paint your bike black and you can get the 4 HP (everybody knows that)
I also have the proof to back it up.crash1292 said:what do you know?...you think S.E. parts are fast
Yes, but you can turn em, right? Do you think your hands are as strong as 4 horses? think about your lawnmower....pa-glazier said:I don't have any numbers for you but our local HD shop has two cam plates on display in the service area. One has gear drive cams and the other has the chain drive with just the rear chain and tensioner. The gear drive spins very easily. The chain drive is a bear to get to turn (and thats without the outer chain and tensioner). You actually have to grab one of the cam lobes to get enough grip to turn the thing. Like I said I don't have any #s but this has to give you a few ponies!
now this sounds like a good plan..be intresting to see how much differance it makesadlerx said:Yes, but you can turn em, right? Do you think your hands are as strong as 4 horses? think about your lawnmower....
4 HP is alot. I am gonna change out my 37b's for 37g's probably before summer, I'll post the baseline dyno's from each and make sure they are done on the same dyno under the same conditions.
Then we'll have at least one example....
I am thinking negligable difference and nothing you can feel. 4hp you should be able to feel, shouldn't you.
I am a skeptic for sure....
Well said. @gree:LAF said:Most of what I have read and seen written on the "4HP" was "can provide up to....".
This has to do with a more precise timing as Chuck stated, and I think I saw parasitic loss from the chain, sprockets, verses just gears.
It don't matter to me as for my build, gears were the ticket.
I don't think anyone should be making a choice of gears versus chain for the 4 HP.
Just wondering why you would go from chain to gear with the exact same grind? Even though I had severe wear (down to the metal at 60,000 miles) if I was not changing cams and going with heavier valve springs I would not have spent the money?? But that is just me. It will be interesting to see your before and after dyno runs.adlerx said:Yes, but you can turn em, right? Do you think your hands are as strong as 4 horses? think about your lawnmower....
DUH!! For the 4 horsepower of course!!!:roflback: :roflback:Thealien said:Just wondering why you would go from chain to gear with the exact same grind? Even though I had severe wear (down to the metal at 60,000 miles) if I was not changing cams and going with heavier valve springs I would not have spent the money?? But that is just me. It will be interesting to see your before and after dyno runs.
I actually have a new set of chains and tensioners that I had planned to put in until I decided on the woods TW6HG cams.
Primary reasons for people to convert to gear drive are:Saxxon said:You are talking about 4hp!
I bet there will be not so mutch increase just of friction loss.
But say you get 4hp, will you feel it? I dont think so.
I read mutch about gear vs chain drive and to me its more about faith than knowledge. HD would never build its motors in such a way if their QA will not be happy with that. And even the SE products came with chains.
Talked to my best friend, a mechanic for over 20 years (Moto Guzzi Racing und now HD).
He told me that the TC motor is one of the best designed motors he ever saw.
He pointed out that we are talking about a 5-6000 RPMS motors and not about 14,000 RPM Superbikes, so up to 4 degree variance is no problem and he also mentioned that roller rockers were not needed.
For racing go with the gear drive, for normal life stay on chain drive and inspect them on a regular basis (20,000).
Just my $.02,
Saxxon
Don't have a solid number but it's enough for most builders looking for power to go to gear drive. Also enough reason for Ford SVO engines to use gear drive.csoday said:Vienna Hog, I'll give you #1.
As far as #3, nope. I think you will find that most engines, car or bike with overhead valves use chain drive and those chains can be up to 36" long. What is their timing variance?
A lot of builders use billet cam support plates and platinum plugs also. :whatever:jasilva said:Don't have a solid number but it's enough for most builders looking for power to go to gear drive. Also enough reason for Ford SVO engines to use gear drive.
Joe
