1 - 2 of 2 Posts
2005 Road King Classic
Just installed 37G's. Gear lash is zero between cam gears. After I installed them they seem to be binding. The cams will spin freely, but if I turn the cams slowly, in one half the turn, you can feel each tooth. I have to actually "click" through using a little pressure.
Are they OK or do I need a smaller cam gear?
Well it looks like lots of your work was done by GMR so I'm sure that the guru will pipe in here soon, but IMO it sounds tight to me. It would be better to be slightly loose than too tight. Of the 3 gear choices I am assuming you have the standard (middle size) running now?
1 - 2 of 2 Posts
