1 - 9 of 9 Posts
In doing a top end rebuild, I nicked my base gasket surface. Any advice on repairing this before I slap it all back together? My dad suggested sand paper of varying grits with a sanding block. I am nervous to ruin the sealing surface and need machining work done.
266108
Is the imperfection on the edge is what you are talking about,then just remove the high point without disturbing the rest of the mating surfaces.
Yes that edge; sorry I forgot to mark it, I fixed the photo. How would you suggest going about taking the edge down, though?
I'd use a fine tooth file then finish with emory cloth and finally scotch brite
sandpaper and or after a file depending on how tall it is,,, just knovk the high edge down...
you can also use a tiny ball peen hammer (8oz) to knock it back down with gentle taps,, then finish with sandpaper wet or dry, of around 240-3320 grit
looks like a pry bar divot,,, i use a rubber hammer to knock stuck cylinders loose.. im famous for leaving no mechanics tracks on ennines ive rebuilt..
Before sanding or filing, get a piece of moderately thick steel that can be placed across that area of the case and tap on it with a hammer. The idea is it to push as much of the displaced metal back into position. If you are lucky, there will not be any need for sanding or filing.
1 - 9 of 9 Posts
