Screamin' Eagle
I have an '04 FDXI with drag bars and a speedo mounted off the lower bolts of my handle bars. I am looking to add a small tach with shift light or a combo gage with speedo/tach/shift light. Is anyone aware of something that would work? I have looked at stuff from dakota digital and autometer, but haven't seen anything yet that has compelled me to buy.
I know this doesn't necessarily fit here though I wasn't sure where else to put this thread and thus far, all of your advice has been great. Thanks.
the speedo kit from thunderheart. it has speedo, tach, shift lite, other stuff. is 5" diameter and you can bar mount it with a little imagination.
i think it is thunder-heart.com
sold by zippers
Check out my tach at www.speedwayinstrument.com
Justin
Screamin' Eagle
It is set at 5700; what would you suggest? It can't be changed once set in the program.
Justin
ericsenf said:
OK... This is sweet. I see from the video it blinks at redline, can this be set lower than redline to be used as a shift light?
Screamin' Eagle
Discussion Starter #7
Justin
I opted for something a bit larger and center mount on the bars. I would suggest something that is user programmable as with a modded engine, you will determine optimal shift point after the dyno tune.
