So, let me start this with a thank you to the forum in general.
The bike is an 88 FXRS. 35,000 miles on the clock.
I have my outer and inner primary off for a re-gearing that I just completed. I’m at the point where it’s ready to go back together - kind of. I replaced my shift lever coming off of the transmission and while I was face to face with the trans pulley I noticed some moisture around the pully nut. “Ohh boy” I said to to myself....(the water droplet on the bottom right of the pulley is because it’s raining out at the moment) I have the extended socket & centering donut needed in the garage to remove the nut but haven’t had to use it yet. Is today my lucky day?
Now, I’ve got the factory service manual on hand and I just can’t wrap my head around what I gotta do to right this. After reading a bunch of past posts online across the forum and web it is to my very loose understanding (if that’s what you want to call it ) that there is a seal, behind a race, in front of a bearing? Please correct me if I’m wrong..
As bad as I want to ride, I’d prefer to order whatever is needed and nip this in the rear and upgrade if possible while I’m in here learning as I go.
Also it seems I have the OEM single lip seal within the inner primary. As well as the OEM bearing. At the moment I have the James gasket kit that has an updated double lip seal. Do I need to remove the snap rings and bearing in order to replace that seal? Or do I pull it from the back side of the inner primary and just press the new seal in? I see some distortion on the bottom side of the bearing/snap ring in picture #3 that concerns me but I am not sure if it should?
Oem seal. with some dings that are concerning to me as well. Don’t want this to cause a leak but if the seal is doing it’s job than it shouldn’t.... right?
Last but not least, the James gasket kit came with 2 seals that look identical but one is marked with a 2 and one with an 8. Im assuming one of them goes where the starter shaft comes into the primary and one goes in the transmission where the starter shaft passes through it. But does it make a difference where each one goes?
Last one and I’m done boys lol...
where does this fancy seal go? Or is it not needed for my application ?
I know it was quite a few questions and a ton of picture room but before I go any further I just want to say thank you to everyone. I’m half lost at this point having never had to replace any of the seals or bearings mentioned or asked about (clearly).
cheers
cheers
