I have replaced the battery (fully charged); start relay and solenoid. the starter continues to spin even if relay is unplugged after starting; 1987 FXR with 99 80ci motor and 90-94 5 speed belt drive primary; Hitachi starter has been replaced.....????
Since I'm not familiar with the belt drive, I have to ask if it has an outer bushing the starter drive runs on? I ask because it sounds like an alignment issue and the starter isn't retracting due to sticking in the bushing.
  • Like
Reactions: Papa Jim Everhart
I would be checking the assembly in this diagram from the parts manual. There are two springs, one further inside being called the return spring (#14).
I screwed that one up in 2003 during surgery when I forgot the small plate that holds that small pin in, and somehow did not lose the pin!
Freaking thing worked though. It’s together correctly now.
Can you post some pictures?
269033
269034
