1 - 2 of 2 Posts
can any of you guys tell me why the fxr used a different primary cover than any other harley model? can the primary be changed from another model ?eg dyna,softail etc
Same as the touring bikes except for the shifter shaft hole as I remember.
Touring has the linkage rod from the foward mounted toe heel shifter and FXR has the shaft coming through the primary.
Also has to do with being the rubbermout 5 speed having a different starter from the solid mount 4 speeds as I recall.
1 - 2 of 2 Posts
