GROUCHO, just curious,,,,,do you have the preload adjusted at it's maximum?GROUCHO said:I seem to bottom out every once in a while while solo...Lots when 2 up...A 2001 bike should not have this problem...I "only" weigh 215...Aftermarket stories anybody????![]()
Ralph said:You have a low rider,and the shocks are 11 3/4" no load. HD has a heavier shock,but they are expensive. $399. I think. You can go with a pair of 12 1/2" and give your self another inch,and stiffen them up. I have a new pair for sale. they have a heavier spring rate. 230/270 lbs/in. , I believe. Or a pair of progerssive's. 90/140 lbs/in. I have some of those too! LOL....But try the preload setting first,and if that don't work,try the longer and heavier ones. ( 12 1/2" ) Hope this works...Ralph
Righty-tighty, lefty-loosey, is what I was always told...sven said:Hi,
I have a 2003 FXDL and in right corners I hit the ground with the lower exhaust pipe! In two up right I hit the ground to often! How do I tighten the shocks? turning them left or right?
Sven
Ladyjaine said:Righty-tighty, lefty-loosey, is what I was always told...
Jean
try heavy duty progressive 440 rear shocks. they solved that problem for me.GROUCHO said:I seem to bottom out every once in a while while solo...Lots when 2 up...A 2001 bike should not have this problem...I "only" weigh 215...Aftermarket stories anybody????![]()
