Yes ,deep and mellow no sharp CRACK :yes:steam said:Steve do the full sacs have a deep low tone relative to other mufflers?
Checkout Bobvic2 on ebay. He does the same thing as fullsac to the mufflers but the ends are more finished.steam said:Thanks Dave, I'm keeping the slip ons with the crossover.
Bobvic uses a 1.750 core. The Fullsacs are 2.0. The Fullsac ends are finished nicely and are welded 360 deg. The pic in their web site is an unfinished muffler.wkohn said:Checkout Bobvic2 on ebay. He does the same thing as fullsac to the mufflers but the ends are more finished.
I didn't buy the Fullsac because of their picture. Maybe they should add a finished picture? Also keep in mind that Bobvic2 does 4 different versions of coring to the mufflers to suit the customers desires. Max 1, 2, 3 and the Superflow. What Bobvic2 told me, "The superflow has a completely different baffle that I designed. I removed the core from the stock muffler and replace it with a 1.75 spiral louvered core. it out performs and sounds better then the Max style muffler. The Max muffler have had the stock baffle re-worked I remove the cone from the end of the muffler shorten the baffle tube and remove the center plugs. They sound good but not as good as the Superflow."Road Bag said:Bobvic uses a 1.750 core. The Fullsacs are 2.0. The Fullsac ends are finished nicely and are welded 360 deg. The pic in their web site is an unfinished muffler.
Just some facts from a satisfied customer.
RB
wkohn, did you install the Bobvic2's with stock headers or did you change over to true duals? If so, which true dual package did you use?wkohn said:I didn't buy the Fullsac because of their picture. Maybe they should add a finished picture? Also keep in mind that Bobvic2 does 4 different versions of coring to the mufflers to suit the customers desires. Max 1, 2, 3 and the Superflow. What Bobvic2 told me, "The superflow has a completely different baffle that I designed. I removed the core from the stock muffler and replace it with a 1.75 spiral louvered core. it out performs and sounds better then the Max style muffler. The Max muffler have had the stock baffle re-worked I remove the cone from the end of the muffler shorten the baffle tube and remove the center plugs. They sound good but not as good as the Superflow."
I haven't installed the Bobvic2 mufflers yet. Been a little to cold here. It is looking like March will be the time to get that on plus the Airstack A/C from J.E.T. It is looking like I will be using the www.Hackerpipes.com true duals with the ceramic coated headers and chrome heat shields for $525.00 plus shipping. For an additional $30 they will weld on bungs for O2 sensors. Do some reading on www.jet-hot.com, www.Swaintech.com, www.hpcoatings.com and www.performancecoatings.com/pci.html web sites about ceramic coatings. Bobvic2 has a lot of people you can contact via ebay that have purchased his mufflers and put them on stock headers and true duals. I believe Bobvic2 has them on true duals for his personal bike.Freddyack said:wkohn, did you install the Bobvic2's with stock headers or did you change over to true duals? If so, which true dual package did you use?
Thanks![]()
Thanks alot for the info. I will dig into the coating websites. Ride Safe!wkohn said:I haven't installed the Bobvic2 mufflers yet. Been a little to cold here. Is looking like March will be the time to get that on plus the Airstack A/C from J.E.T. It is looking like I will be using the www.Hackerlabs1.com true duals with the ceramic coated headers and chrome heat shields for $525.00 plus shipping. For an additional $30 they will weld on bungs for O2 sensors. Do some reading on www.jet-hot.com, www.Swaintech.com, www.hpcoatings.com and www.performancecoatings.com/pci.html web sites about ceramic coatings. Bobvic2 has a lot of people you can contact via ebay that have purchased his mufflers and put them on stock headers and true duals. I believe Bobvic2 has them on true duals for his personal bike.
Your welcome. I forgot one company. http://www.jetcoat.com/homepage.htmlFreddyack said:Thanks alot for the info. I will dig into the coating websites. Ride Safe!![]()
The 2.0 cores do have a slightly deeper sound than the 1.75. There is 2 HP difference between the two on a stock 88. On a 95 with heads and cams, the 2.0 core will gain 4-5 HP over the 1.75.steam said:Hey Road Bag, thanks for the info. I can't possibly imagine why anyone with a stock 1450 twin cam would need more than a 2'' diameter baffling. I believe the full sacs may be deeper sounding and almost more of a cleaner performance type of sound than the Bovic2, although the bovic also sound good.
gnat
