1 - 11 of 11 Posts
Do a search there is a thread a week on this literally. Most people will tell you use the tripmeter. They seem to be better first half of tank. There usually not off by 1/2. You saying at half tank reads empty?
There is away to adjust, I never bothered. Mines not under warranty anyways.
I manly use it to tell me its full. Sometimes forget to reset, and next day try remember. Suppose I could also look in the tank. There is an arm that cane be bent/adjusted. Since its new might want to.
Like I said most people claim best for 1/2 of tank.
Tripmeter is the way to go. Around town I can get around 190-200 miles per tank, fuel gauge reads empty around 170-180. 1/2 tank empty does seem odd.
0043--Licensed to Doof!
Take it to the dealer, it's still under warrantee. Get the manual. You can adjust the float inside your tank, the manual gives good direction on how to get to it.
Has anyone found a way to adjust the level?I have a 03 Ultra that opnly goes to 1/2 full when full.dealer said the sending unit was bad.It goes down to empty but only shows half when you fill it.
1 - 11 of 11 Posts
