Could it be teflon tape reacting to a fuel additive??
HD sells a fuel stabilizer too if I remember right so I wouldn't worry about. Which dealer do you use?Lefty said::gun: Spoke with the service manager at my dealer today and he thought it sounded like a fuel leak where the line meets the valve that got to the sealant around the valve. Didn't ask about additives, etc. Just said to bring it in and he'd take care of it. I'll let you know what it turns out to be when they check it out.
Thanks for the replies!
Lefty
I use Doc's in Kirkwood. They've been pretty good since I had one run in with them over a sportster about 18 months ago. I've heard Ted's is the best in the region, but I live in Kirkwood, too far from Alton. . .Craig, the service manager @ Doc's seems to be competent.cwo2lt said:HD sells a fuel stabilizer too if I remember right so I wouldn't worry about. Which dealer do you use?
Thanks. I haven't been into Ted's but once, too far away - I'm in Arnold. Doc's does seem to have a very good service dept. Only had to use them once and that was just a dyno run.Lefty said:I use Doc's in Kirkwood. They've been pretty good since I had one run in with them over a sportster about 18 months ago. I've heard Ted's is the best in the region, but I live in Kirkwood, too far from Alton. . .Craig, the service manager @ Doc's seems to be competent.
Lefty
csoday said:Sounds like a fuel tank sealent. Stabil won't do that, I've used plenty over the last four years and always run it out with no problems. Teflon sounds like it could have been the culprit and was my first choice until you said a spoon full. Sure there wasn't a goose overhead while you were riding.
