Stuff for sale or trade:
  • 21" Front Laced Sportster Wheel and ME880 Tire $200
    • 43557-00A Wheel Assembly, 21" (Rim is chrome, I believe the rest is stainless steel)
    • Metzeler 880 front 90/90h21 (10,217 miles)
    • Wheel assembly taken off at 18,725 miles)
  • 2003 100th Anniversery Fuel Tank Badges $300
    • 62244-03 Medallion, fuel tank - LH (chrome) - 100th Anniv restricted sale part
    • 62245-03 Medallion, fuel tank - RH (chrome) - 100th Anniv restricted sale part
  • Forward Controls - Stock takeoffs from an '03 at 18k miles $100
    • Shifter peg, not included. All other parts necessary to convert from mid controls are included. Additional engine mount bracket bolts are included, but are not necessary.
    • The left peg is worn. The brake pedal is scuffed on the far right side, making it a few millimeters shorter toward the bottom. Otherwise they are in good condition.
    • I believe they will work with '91 to '03 Sportsters (possibly '86 to '03). You should verify if your bike is pre '99. Comparing the parts to your factory manual is a safe bet, unless you trust your dealers opinion
  • NHRS Hurrican Pushrod Bases $20
    • Did not fit with my powder coated tubes. Gaskets are glued in place with gasket sealer.
    • Part Number: 13-NRHSXLPB Fits 91-03 XL 883 & 1200 and 91-02 Buell Twins
  • Windzone Day Tripper. Compact Toolkit from Beza. Belt wearable
  • PowerTrip Mesh Jacket - size Medium
  • Progressive 412 11.5" black shocks (1,827 miles) $100
  • Stock 11 3/4" Shocks (taken off at 16,898 miles) $50
    • 54568-92 Shock Absorber, complete (low) (2)
  • SE Air Cleaner and Cover. K&N filter $40 for SE kit, $50 more for the ham can cover and remaining stock pieces
  • Stock Slipons with baffles punched
  • Stock Slipons w/ Baffles (bought on eBay)
  • Willie and Max Raptor Compact Slant Saddle Bags #SB801 $40
    • size: 12”x9 ½” x 5 ½”
    • hook and loop (Velcro) closure
  • Stock 883 Pistons
  • Stock/replacement 883 Ignition Module - less than 20 miles on it
  • Stock exhaust header and cycle shack slip ons (assuming I get a new exhaust before spring)
Here's some stuff I'm looking for:
  • Ohlins rear shocks
  • Performance works 15" shocks
  • Floating brake rotor (preferbly with black inner ring)
  • Brembo brake caliper (preferbly gold) and QTM bracket
  • Dual Disc Conversion kit HD# 44090-00A
  • Kriss Headlight Modulator
  • Heavy Cycle LED tail light (for XL or for VRod)
  • Andrew N2 Cams
  • Progressive replacement fork springs #11-1523
  • Biker's Friend Roll Bag
  • Ghost Brackets or Easy Brackets
  • Mustang Sport Touring Seat #75733
  • FXRG Midweight Jacket
  • 2:1 Exhaust (preferbly black)
I've listed prices for some items, for other items I'm entertaining offers thru Private-Message. Thanks
Discussion Starter · #2 ·
Pics
Seasoned Prime Member
Are these take offs or unused? Are they from the sporty?:chopper:
They are takeoffs from the Sportster.
