1 - 1 of 1 Posts
Barely been used (I don't think I've even used it for an actual repair).
$20 + shipping (or you pick it up)
If you're local (Rochester, MI), I'll also consider trading for beer ;-)
Ultima-Tool TM Multi-Tool
  • Adjustable wrench
  • Needle nose pliers (spring loaded)
  • Large knife blade
  • Wood saw
  • Flat screwdriver
  • File
  • Wire cutter/stripper
  • Bit driver w/ adapter
Essenti-Tool TM Multi-Tool
  • Small knife blade
  • Flat screwdriver
  • File
  • Hole punch
  • 10mm wrench
  • Scissors
Specially-designed belt holster/carrying case
  • Cable ties
  • Mechanic's wire
Included Bits
  • Slotted screwdrivers:
  • 1/8", 5/32", 3/16", 1/4"
  • Phillips screwdrivers:
  • #0, #1, #2, #3
  • SAE hex keys:
  • 1/16", 3/32", 1/8", 5/32", 3/16", 7/32", 1/4"
  • Metric hex keys:
  • 2mm, 2.5mm, 3mm, 4mm, 5mm, 5.5mm, 6mm
  • Torx:
  • T8, T9, T10, T15, T20, T25, T27, T30, T40
It was $35 from Beza + shipping. Yours for $20.
1 - 1 of 1 Posts
