I picked up a new front wheel and I installed the new bearings incorrect. The instructions call to have the left side(brake rotor side/primary side) bearing installed first. Well, I installed the right bearing first. Everything went back together fine but now I see that the brake rotor is not completely centered in the caliper.
I get the feeling I'm going to have to pull those bearings, buy a new set and install them in the correct order to correct the spacing issue.
Am I correct in that assumption?
