Unplug them from under the tank. Then you'll need to disassemble the connector so you can run the wires thru the bars. Write a diagram of the color coded wires before disassembly. The brake light switch is inside the switch housing, but the actuator for that switch is on the brake lever. When the switch in depressed, the light is off. Watch as you remove it, it'll be clear.
