21 - 28 of 28 Posts
'08 and up Dynas (all Dynas) take #9276 bearings, which are 25mm.
'06-'07 Wide Glides (and '04-'05 non WG) take #9247 bearings, which are 1".
'00-'05 Wide Glides (and '00-'03 non WG) take #9267 bearings, which are 3/4"
p.s. you're gonna need the 1" inner bearing spacer too if you change the bearings to 1".
Hey bud I bought a set of 41mm forks for my dyna lowrider 1996 wut size bearings will I need in neck and in hub I don't have a axle yet either thanks in advance
Why would you need a bearing reducer when you are trying to use a bigger axle? A reducer makes it sound like the hole (ID) needs to be smaller. But you are going from small to large, if it's possible.
Unless you plan on boring out the forks for a bigger axle, a 1-inch axle won't fit. If their stock Harley Wheels why not just change the bearings from 1in to 3/4? The outside diameter of the bearings are the same it's just the inside that's different so they are interchangeable to the wheel. But you will need to find a three quarter bearing spacer.
21 - 28 of 28 Posts
