1 - 8 of 8 Posts
How can i do away with the front air suspension
Any recommendations thanks 2000 roadking police
No you cannot eun without oil,,, oil is needed for damping,, appx 12.4 Oz per fork, you can use a plug in the drilled caps of you do not want to change the caps to solid ones...just use sealer on the plug so it won't leak...
No oil is needed for damping,, appx 12.4 Oz per fork, you can use a plug in the drilled caps of you do not want to change the caps to solid ones...just use sealer on the plug so it won't leak...
I think you meant no air, only oil is needed for dampening. Autocorrect?
Thank you jammer, I fixed it... I think that was all me,,,, lol,,,, what I meant was, no, you can't do away with the oil, oil is needed for damping,,, then, the short, stupid sounding version got posted.... my bad,,, even a broken clock is right twice a day.....
1 - 8 of 8 Posts
