Only a few days left to take advantage of Progressive's Spring Special!
Click Here For Free Spring Redemption Form
Click To Order Progressive 944's
Progressive Suspension has unveiled another breakthrough design called Frequency Sensing Technology (FST) for its unique ability to dynamically adjust damping as you ride.
*NEW* Ultra-Low series shocks give you the travel of 12.5" shock, but sits like a 11" shock!
Click To Order Progressive 444's
After more than a decade of ruling the roads with our road proven 440 Series shocks, We've unveiled another breakthrough design. Dubbed Frequency Sensing Technology (FST) for its unique ability to dynamically adjust damping as you ride. The result is superior performance no matter the road conditions. A top mount threaded preload adjuster allows for fine tuning with a simple twist of the cap.
- Frequency Sensing Technology (FST) dynamically adjusts damping for optimum ride quality
- Deflective disc valving
- Specifically designed to deliver a comfortable ride at a 1" lowered stance. The Ultra Touring shocks utilize all the suspension travel provided by these 13" eye to eye units, but provide a 1" lowered ride height normally achieved by installing a shorter, 12" E/E, set of shocks.
- The unique Ultra Touring spring combination not only delivers a lowered ride height while it's being ridden, but also while it's on the stand
- This lowered stance makes it easier to manage your bike at intersections and parking lots, not to mention just swinging your leg over the seat
- IAS technology - Patented damping technology that separates wheel movement from chassis movement
- Adjust spring pre-load by hand, no special tool needed
- Progressive rate main springs specifically designed for touring
- High pressure gas charged for consistent performance
- Fits 80-Up FLH, FLT (exc. Tri Glide)
- Uses all new FST Frequency Sensing Technology). Allows the shocks to sense the frequency of a bump and automatically adjust damping for superior ride quality
- Special tools no longer needed to adjust, spring pre-load can be adjusted by hand
- High-pressure gas charged with a progressive rate spring creates a consistent performance
- Standard or heavy-duty spring rate with a black or chrome finish
- Made in the U.S.A.
