1 - 2 of 2 Posts
1) What weight/amount for new progressive springs? service manual says Type E which seems light (10w) and 12oz which seems a bit much.
2) Tips for draining on Deuce and removing springs
g-smitty
I replaced the fatory oil with SE oil before deciding if new springs were needed. The SE oil did the trick.
I jacked up the bike, removed the top cap screws and removed each lower drain screw. I tipped the fork left and right for ~30 minutes each side to ensure that each tube was drained.
I use the markings on the side of the SE Oil bottle to suffice as fl. measurement. Work great for me. 100% improvement over stock.
1 - 2 of 2 Posts
