I just bought a HD Fog Lamp Kit that installs on the engine guard of my Street Glide. I've got a couple of install questions... First of all the push button switch that comes in the kit is to be installed under the left side switch housing. Is there a way to put a rocker switch in the inner fairing like the Ultras come with for their spot lights?
Also the kit has a low beam wire that will allow the lamps to only work when the low beams are on. Can I just skip this wire since I want them to work even if the high beam is on?
THanks for your help.
Joe
Joe
