Flyin must say that your bike is very cool indeed can you give us some more info on it?
1.What year and model.
2.What size and make rear shocks.
3.Who is the fender made by.
4.Whos wide tyre kit did you use and how much offset. Looks like you have a 25mm offset and have used a .9" offset chain front sprocket.
5.What lenght forks and is the any rake added to them.
How does the bike handle with the wide tyre kit.
Really love the bike it looks mean.
Thanks Dyns Gaz
Thanks........... Glad you like it.
1. 2001 FXDWG
2. 11" Progressive 412's
3. Front & Rear by RWD
4. The tire conversion is by Custom Valley and came with everything for it to be done from what I can remember.
5. Fork legs a +2 over stock. The frame has no added rake but I am running a 5 degree tree from Covington customs.
I have had no problems with the way the bike handles. I love it.........
I am in the process of trying to find someone here in Hawaii who can rake the frame. If I can find someone I will be adding 4 degrees to the frame.:thumbsup:
Thanks again.
Thanks for the specs they have given me some good ideas.
I have fxdx so going yo use 2" over forks with 3 degrees of rake to give a simular look.
Tried to look up your fenders but no luck, is there a web site for them??
Cheers Gaz
Cheers Gaz
Here is the link for their site. http://www.russwernimont.com/
The front fender is called a ( Long O.F.C )
And the rear is the Longshot That I cut up to look like a Paul Yaffe ( Spike )
