Dunno if this'll help
M-1119 1 of 2
SERVICE BULLETIN
M-1119 Safety Recall Code 0105 January 10, 2002
FRONT FENDER TIP LAMP JUMPER HARNESS RETENTION
Purpose
As recently advised in ML-370, Harley-Davidson has learned
that the clips retaining the front fender tip lamp jumper harness
can become detached on certain 2001 and 2002 FLT
model motorcycles. This condition could cause the wiring to
become frayed and shorted, possibly causing the lighting
fuse to blow. A blown lighting fuse leaves the vehicle without
an operational headlight, passing lamps, front fender tip
lamp, tail lamp and running lights.
In the interest of motor vehicle safety and customer satisfaction,
Harley-Davidson has elected to initiate a voluntary recall
(Campaign 0105) to add four metal clips in the fender well,
as well as replace the existing harness if damaged. See
REQUIRED DEALER ACTION to perform the recall service.
This recall applies to all 2001 and 2002 FLT model motorcycles
equipped with a front fender tip lamp and assembled/
shipped from the York, Pennsylvania assembly plant between
March 5 and October 25, 2001, specifically, FLHR, FLHR-I,
FLHT, FLHTC, FLHTC Shrine, FLHTC-I, FLHTCU-I,
FLHTCU-I Shrine, FLHP-I, FLHPE-I and FLHTP-I.
