I was wondering if the FLH stock or even the aftermarket exhaust designed for the FLH will bolt up and look as though it was designed to work on a FLS fatboy?
I would probably fit, but you would have nothing to hang the mufflers off. The FLH mufflers hang off of the saddlebag supports, and on the Fatboy there are none.
The bags sit on rails that are hard mounted to the frame and fender. If you go thru all that mess to install rails and hard bags, well then you'd have a RoadKing!! Seriously, I don't see any easy or CLEAN way to mount and hang the mufflers on a fat boy.
