Do you have a shop manual for your bike? Mine has about 55 pages of instructions for diagnostics for the carbureted ECM. Some pertain to the use of the HD Scanalyzer tool. If that isn't available, it calls for jumpering a couple of wires in the data link connector and reading flashes of the check engine lamp. It doesn't say anything about pushing turn signals or flashing hazard lights. There might be slight differences between diagnosticd for your ECM (32478-99A) and mine (32478-99) but I can't see how they would be drastically different like that. Fuel injected might be a lot different, as it uses a completely different ECM. Which you don't have now and never had.
G Man's first section about how to check fir DTCs is good, but all that MM stuff after about retrieving codes doesn't apply to a carbed ECM.
That being said, when I replaced the factory ECM with my aftermarket one, diagnostics became completely different. But it still goes through the check engine lamp, and it is automatic when a condition occurs. The only one I have experienced is a random high voltage situation that would come up while I was riding. The ECM would kill the signal to the speedo and blink the lamp 5 times and then the speedo would come back to life. There is about 1 page of diagnostics with the Crane instructions covering the 7 possible faults it detects.
I called Dynajet tech support and they told me this module does not store any trouble codes that I would still have to clear any per the factory procedure.
Sounds like double talk to me. If it doesn't store codes, then how is there anything to clear? I would call them back and harangue them until they gave me a link to the actual instructions, not just some verbal hint over the phone from somebody that probably wasn't working for their company and might not even been alive when this ECM was designed. It's even possible that the instructions would tell you what 6 flashes mean, whether whoever you talked to knew or was clueless.
Did you address the 6 flashes of the hazards during your conversation to see if sounded like anything they would know about? If they said no, you could quit thinking it was a trouble code and look elsewhere for the solution.
I hope you figure this out soon. I'm getting worn out giving you a hard time about it.
