Doing some research, found there are two ways to pull OBD codes in 2001, and on some models 6 T/S flashes can be a code stored. This is the other way.
1 Set RUN/OFF switch to OFF
2 Turn IGN key ON-OFF-ON-OFF-ON
3 Press left turn switch 2 times and
release
1-3 flashes turn signals & indicators
depending on vehicle configuration
(See section under 3.3 TSM/TSSM
VEHICLE DELIVERY regarding battery
disconnects.)
1 flash-Worldwide TSM, no
security
2 flashes-North American/
Domestic configuration
TSSM
3 flashes-European/HDI con-figuration
TSSM
4 Press right turn switch 1 time and
release 1 flash turn signals & indicators
5 Press right turn switch 1 time and
release 2 flashes turn signals & indicators
6 Press right turn switch 1 time and
release 3 flashes turn signals & indicators
7 Press left turn switch 1 time and release turn signals & indicators flash to indicate
trouble codes See Table 3-13.
8
To clear codes, press and hold left turn
switch for 4-5 seconds until confirmation
is received
9 Turn IGN key OFF
This is the thread I pulled it from,
I've found various procedures documented on other sites pertaining to how to do do this. ie. Jumper data link pins 1 and 2 (didn't work cycle ignition switch on 3 sec, off 3 sec, repeat (didn't work Apparently there is a way to get the ECM to spit out its codes as others have done it, but I...
www.v-twinforum.com
